跳转到主内容
加入维修社区 - 创建账户
Xbox One Elite Controller (Model 1698) LED Replacement
你所需要的
  1. Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: 步骤 1 中的图像 1,2 Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: 步骤 1 中的图像 2,2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
    询问修复机器人
    添加评论
  2. Xbox One Elite Controller (Model 1698) LED Replacement, Removing the back panel screws: 步骤 2 中的图像 1,1
    • Remove the 5 Torx Security Bit (TR9) screws.
    添加评论
  3. Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 步骤 3 中的图像 1,3 Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 步骤 3 中的图像 2,3 Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: 步骤 3 中的图像 3,3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
    询问修复机器人
    添加评论
  4. Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: 步骤 4 中的图像 1,2 Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: 步骤 4 中的图像 2,2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
    添加评论
  5. Xbox One Elite Controller (Model 1698) LED Replacement, Screws on controller motherboard: 步骤 5 中的图像 1,1
    • Remove the 2 Torx (T6) screws.
    询问修复机器人
    添加评论
  6. Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: 步骤 6 中的图像 1,2 Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: 步骤 6 中的图像 2,2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
    添加评论
  7. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: 步骤 7 中的图像 1,2 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: 步骤 7 中的图像 2,2
    • Pull up from the "top" side of the controller on the daughterboard.
    添加评论
  8. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 步骤 8 中的图像 1,3 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 步骤 8 中的图像 2,3 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: 步骤 8 中的图像 3,3
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
    询问修复机器人
    添加评论
  9. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: 步骤 9 中的图像 1,2 Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: 步骤 9 中的图像 2,2
    • Unscrew the 6 Torx (T6) screws.
    添加评论
  10. Xbox One Elite Controller (Model 1698) LED Replacement, Replace the LED: 步骤 10 中的图像 1,1
    • Desolder the original LED from the motherboard of the controller. Do this for both sides of the LED until all of the old solder is removed.
    • Solder on your new LED.
    • Make sure it is installed the same direction as the old LED, or you can burn out the new LED.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
EasyAsABC123
于01/22/10注册
2,557 声望
创作了5篇指南
7指南评论
So question I’m having troubles with my elite controller every time I go to plug it in and the charging port in the back of the controller it starts to smoke what’s my problem
Dustin Dykstra - 回复 分享
It sounds like it could be a lot of things…
smoke is obvious a dead stop (stop plugging it in until you repair it).
I would first check the charge port and make sure it is firmly attached if it isn’t you can easily replace the usb port. Next it could be the mainboard charging circuit. if it is this…replace the controller is likely the ideal solution.
EasyAsABC123 - 回复 分享
I was looking to do this mod for fun. Do you have or know where I can get the led part number? A schematic or bom would be nice. Thanks
Clayton Armagost - 回复 分享
0805 SMD LED Diode Lights
i bought these https://www.amazon.com/gp/product/B01CUG...
Thank you. I ordered them so we will see what happens.
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 78
总计 9,199
