跳转到主内容
加入维修社区 - 创建账户
Wireless card replacement
你所需要的
精选文档
    1. Wireless card replacement, Remove the battery: 步骤 1 中的图像 1,3 Wireless card replacement, Remove the battery: 步骤 1 中的图像 2,3 Wireless card replacement, Remove the battery: 步骤 1 中的图像 3,3
      • Turn the laptop upside down and gently lay it down on a flat surface.
      • Slide the battery release latch to the right and the battery will pop up slightly.
      • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
      • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
      询问修复机器人
      添加评论
    1. Wireless card replacement, Remove the captive screw of the service door: 步骤 2 中的图像 1,1
      • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
      询问修复机器人
      添加评论
    2. Wireless card replacement, Remove the service door: 步骤 3 中的图像 1,3 Wireless card replacement, Remove the service door: 步骤 3 中的图像 2,3 Wireless card replacement, Remove the service door: 步骤 3 中的图像 3,3
      • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
      • Continue along the short edges.
      • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
      询问修复机器人
      添加评论
    3. Wireless card replacement, Identify the components: 步骤 4 中的图像 1,1
      • RAM memory modules
      • HDD (Hard Disk Drive)
      • mSATA SSD slot
      • Wifi & BT module (Wireless card)
      询问修复机器人
      添加评论
    1. Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 步骤 5 中的图像 1,3 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 步骤 5 中的图像 2,3 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      询问修复机器人
      添加评论
    2. Wireless card replacement, Substitute the wireless card: 步骤 6 中的图像 1,3 Wireless card replacement, Substitute the wireless card: 步骤 6 中的图像 2,3 Wireless card replacement, Substitute the wireless card: 步骤 6 中的图像 3,3
      • Grab the standard wireless card as it is shown in the first picture and gently pull it away at the tilt angle.
      • Place the M2.0×2.5 screw in the hole of the new wifi module, tilt it, and gently insert it in its slot. Then press the wireless card down with a hand and fasten the screw using a PH #00 with the other one.
      • Using the tweezers center and hold the connectors of the antenna cables over their terminals and then press them straight down gently using your finger. Cable 1 goes with the Main terminal and Cable 2 with the Aux terminal.
      询问修复机器人
      添加评论
结论
Well, that’s it! Take a short break if you like and then start to reassemble your laptop from the step #3 in reverse order. Once you turn the laptop on, install the new drivers and it's done ;) Cheers
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 44
总计 2,839
