跳转到主内容
加入维修社区 - 创建账户
Whirlpool Refrigerator Control Board Replacement
你所需要的
    1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: 步骤 1 中的图像 1,1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      询问修复机器人
      添加评论
    1. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 1,2 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 2,2
      • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
      • Remove the screw(s) securing the two dispenser panels.
      添加评论
    2. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 3,3
      • Pull the dispenser panels straight down to separate them from the chassis.
      • Remove the dispenser panels.
      询问修复机器人
      添加评论
    3. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: 步骤 4 中的图像 1,1
      • Remove the screw(s) securing the control board.
      询问修复机器人
      添加评论
    4. Whirlpool Refrigerator Control Board Replacement: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Control Board Replacement: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Control Board Replacement: 步骤 5 中的图像 3,3
      • Tilt the bottom of the control board away from the chassis to release its clips.
      • Pull straight down to separate the control board enough to access its connectors.
      询问修复机器人
      添加评论
    5. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 3,3
      • Disconnect the connectors attached to the control board.
      询问修复机器人
      添加评论
    6. Whirlpool Refrigerator Control Board Replacement, Remove the control board: 步骤 7 中的图像 1,1
      • Remove the control board.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
nicO
于04/14/15注册
15,990 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 156
总计 6,317
