跳转到主内容
WRS315SDHW Dispenser Assembly Replacement
你所需要的
  1. WRS315SDHW Dispenser Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 1,2 WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 2,2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: 步骤 3 中的图像 3,3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Dispenser Assembly Replacement, Unfasten the control board: 步骤 4 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Dispenser Assembly Replacement: 步骤 5 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement: 步骤 5 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement: 步骤 5 中的图像 3,3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: 步骤 6 中的图像 3,3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Dispenser Assembly Replacement: 步骤 7 中的图像 1,2 WRS315SDHW Dispenser Assembly Replacement: 步骤 7 中的图像 2,2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Dispenser Assembly Replacement, Remove the control board: 步骤 8 中的图像 1,1
    • Remove the control board.
  9. WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: 步骤 9 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: 步骤 9 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: 步骤 9 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  10. WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: 步骤 10 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: 步骤 10 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: 步骤 10 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  11. WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: 步骤 11 中的图像 1,2 WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: 步骤 11 中的图像 2,2
    • Reposition the cables so they lay in front of the top plastic clip.
  12. WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 12 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 12 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: 步骤 12 中的图像 3,3
    • There are two plastic clips that secure the dispenser assembly in the chassis.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clip to completely separate the dispenser assembly from the chassis.
  13. WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: 步骤 13 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: 步骤 13 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: 步骤 13 中的图像 3,3
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  14. WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 14 中的图像 1,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 14 中的图像 2,3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: 步骤 14 中的图像 3,3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  15. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser assembly: 步骤 15 中的图像 1,1
    • Remove the dispenser assembly.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 46
总计 808
