跳转到主内容
Water Damage on main board of Nokia 206 RM873
你所需要的
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 步骤 1 中的图像 1,3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 步骤 1 中的图像 2,3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 步骤 1 中的图像 3,3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: 步骤 2 中的图像 1,2 Water Damage on main board of Nokia 206 RM873: 步骤 2 中的图像 2,2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: 步骤 3 中的图像 1,2 Water Damage on main board of Nokia 206 RM873: 步骤 3 中的图像 2,2
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: 步骤 4 中的图像 1,3 Water Damage on main board of Nokia 206 RM873: 步骤 4 中的图像 2,3 Water Damage on main board of Nokia 206 RM873: 步骤 4 中的图像 3,3
    • Remove keyboard by prying it open with a spudger.
    • The keyboard is secured with adhesive, be careful!
  5. Water Damage on main board of Nokia 206 RM873: 步骤 5 中的图像 1,3 Water Damage on main board of Nokia 206 RM873: 步骤 5 中的图像 2,3 Water Damage on main board of Nokia 206 RM873: 步骤 5 中的图像 3,3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  6. Water Damage on main board of Nokia 206 RM873: 步骤 6 中的图像 1,2 Water Damage on main board of Nokia 206 RM873: 步骤 6 中的图像 2,2
    • How and where to use the cotton swabs.
结论
16等其他人完成本指南。
Kevin D
于05/02/14注册
7,195 声望
创作了21篇指南
4条评论
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - 回复
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - 回复
Nokia 206 display and charger pin
Mithilesh Yadav - 回复
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 10,690
