跳转到主内容
Wahl Lithium Ion Trimmer  Slide switch Replacement
nathan
nathan3 其他贡献者
最后更新于 January 21, 2025
没有估计
中等
语法警察
要点符号!
令人困惑的文字
需要更好的图片
缺少前提条件
This guide will teach you how to replace the power switch on your razor instead of going and buying a new razor all together. This switch has a plastic mechanism that is connected to the slider from the inside. The plastic switch is in between the battery and motor that controls power. This switch could get jammed or broken off.
  1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: 步骤 1 中的图像 1,1
    • Start at the last step of the disassembly guide.
  2. Wahl Lithium Ion Trimmer  Slide switch Replacement: 步骤 2 中的图像 1,1
    • remove the inside on the razor which includes the chip set, battery, motor and switch.
  3. Wahl Lithium Ion Trimmer  Slide switch Replacement: 步骤 3 中的图像 1,1
    • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
  4. Wahl Lithium Ion Trimmer  Slide switch Replacement: 步骤 4 中的图像 1,1
    • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
  5. Wahl Lithium Ion Trimmer  Slide switch Replacement: 步骤 5 中的图像 1,1
    • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
结论
另外一个人完成了本指南。
nathan
于10/22/13注册
1,422 声望
创作了6篇指南
一条评论
Where can you source this part from?
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 3,412
