跳转到主内容
Wahl Lithium Ion Trimmer  Electric Motor Replacement
nathan
nathan2 其他贡献者
最后更新于 July 15, 2024
没有估计
中等
需要更好的图片
缺少前提条件
更好的介绍
  1. Wahl Lithium Ion Trimmer  Electric Motor Replacement, Electric Motor: 步骤 1 中的图像 1,1
    • Refer to the 4th step in disassemble process to begin replacement of motor.
  2. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the chip set, battery and motor as one piece.
  3. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 步骤 3 中的图像 1,1
    • In this step focus on the motor, ignoring the chip set and battery. Here you will be able to remove the motor from the wires.
  4. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 步骤 4 中的图像 1,1
    • After the wires are removed and the motor is detached use the replacement motor you purchased and reconnect the wires.
结论
另外一个人完成了本指南。
nathan
于10/22/13注册
1,422 声望
创作了6篇指南
一条评论
Did you actually find this motor (or an equivalent) for sale? Where?
Marshall Eubanks - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 2,891
