跳转到主内容
Wahl Lithium Ion 5537C Blade Replacement
Osman Saeed
Osman Saeed 另一个贡献者
最后更新于 July 15, 2024
4 - 8 分钟
简单
Consumers love grooming electronics which help save them their time in their normal busy life. A electrical shaver by Wahl is widely used and accepted worldwide, so users sometimes throw out their electrical shaver just because of a malfunctioning blade. You would find this guide the best one to eliminate the need to shop for new trimmers over a period of time and also the cheapest way to take care of your hygiene. Be aware of the used blade and bacteria might be harmful. Always dispose off metal blades where they are out of reach of small kids as blades can be fatal. Hence this guide helps users to replace their current shaver blade with a new one.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: 步骤 1 中的图像 1,2 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: 步骤 1 中的图像 2,2
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: 步骤 2 中的图像 1,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 2 中的图像 2,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: 步骤 3 中的图像 1,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 3 中的图像 2,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 3 中的图像 3,3
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: 步骤 4 中的图像 1,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 4 中的图像 2,3 Wahl Lithium Ion 5537C Blade Replacement: 步骤 4 中的图像 3,3
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
结论
另外一个人完成了本指南。
Osman Saeed
于07/11/21注册
109 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 77
总计 1,554
