跳转到主内容
Vivitar XO 7 Motherboard Replacement
你所需要的
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: 步骤 2 中的图像 1,1
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Vivitar XO 7 Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: 步骤 5 中的图像 1,2 Vivitar XO 7 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: 步骤 6 中的图像 1,2 Vivitar XO 7 Motherboard Replacement: 步骤 6 中的图像 2,2
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: 步骤 7 中的图像 1,1
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: 步骤 8 中的图像 1,2 Vivitar XO 7 Motherboard Replacement: 步骤 8 中的图像 2,2
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: 步骤 9 中的图像 1,1
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: 步骤 11 中的图像 1,2 Vivitar XO 7 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: 步骤 16 中的图像 1,2 Vivitar XO 7 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
结论
James Lunn
于01/20/15注册
116 声望
撰写一个指南
团队
USF Tampa, Team 11-1, Blackwell Winter 2015 USF Tampa, Team 11-1, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 906
