跳转到主内容
加入维修社区 - 创建账户
Visual Land Prestige Pro 7D Reset Button Replacement
你所需要的
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      询问修复机器人
      添加评论
    2. Visual Land Prestige Pro 7D Reset Button Replacement: 步骤 2 中的图像 1,1
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      询问修复机器人
      添加评论
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: 步骤 3 中的图像 1,2 Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Use the tweezers to lift the grey connector, located next to the reset button, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
      • Although not necessary for replacing the reset button, it is highly recommended to disconnect the ribbon. This ensures it will not get damaged during desoldering.
      询问修复机器人
      添加评论
    2. Visual Land Prestige Pro 7D Reset Button Replacement: 步骤 4 中的图像 1,3 Visual Land Prestige Pro 7D Reset Button Replacement: 步骤 4 中的图像 2,3 Visual Land Prestige Pro 7D Reset Button Replacement: 步骤 4 中的图像 3,3
      • Soldering guns are hot and can easily damage the device.
      • Desolder the four side dots holding the reset button in place.
      • If this is your first time desoldering, here is a helpful guide to show you 如何焊接和拆焊.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G41
4 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 3,933
