简介
This guide will show you the steps to replacing the battery. Soldering and de-soldering will be necessary.
你所需要的
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Pry a thin tool under the battery.
Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
3等其他人完成本指南。
