Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement
简介
转到步骤 1What you can expect from this guide is a step by step process on how to remove the plastic case on a Verizon Ellipsis Jetpack MHS800L.
在这个步骤中使用的工具:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
在这个步骤中使用的工具:iFixit Opening Picks (Set of 6)$4.99
Use a plastic pick at the seams and pry open the case.
2等其他人完成本指南。
