跳转到主内容
Verizon Ellipsis Jetpack MHS800L Battery Replacement
Richard J Porras
Richard J Porras4 其他贡献者
最后更新于 March 1, 2023
5 - 10 分钟
中等
需要更好的图片
更好的介绍
What you can expect from this guide is a step by step process on how to remove the battery on a Verizon Ellipsis Jetpack MHS800L.
你所需要的
工具
查看更多...
  1. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: 步骤 1 中的图像 1,3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: 步骤 1 中的图像 2,3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: 步骤 1 中的图像 3,3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 2 中的图像 1,3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 2 中的图像 2,3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 3 中的图像 1,1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
  5. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 5 中的图像 1,1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: 步骤 6 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 7 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Battery Replacement: 步骤 9 中的图像 1,1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
结论
6等其他人完成本指南。
团队
IUPUI, Team 3-3, Baechle Spring 2016 IUPUI, Team 3-3, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S3G3
4 名成员
创作了6篇指南
5条评论
I'd like to let you know that after step 9, it is possible to unwrap the battery and break loose the circuit board on the battery. At which point you can reinstall the circuit board in the router with no battery attached. This makes the Jetpack plug-in only which is all I need it for anyways. It was a great and free fix for my swollen battery.
Thanks for the article!
Jeff Lovett - 回复
Opps, I think that steps 3 & 4 have been reversed. You can't get to the "3 additional screws" until you're looking at the red cover which is below the black cover that needs to be pried off first.
Otherwise, the process seems to be going well.
bevrievley - 回复
It’s unclear. Once you unscrew that first screw, you have to remove the TOP black portion (the picture looks like you’re removing the bottom). Once you remove that top portion, the red plastic is exposed, revealing the three other screws.
imsonnyburnett -
And -- continuing with step 5, there are some plastic "snap" locks between the red and black covers -- 5 by my count, 2 along each of the long edges, 1 along the charging port edge. Always good to pry carefully.
Once apart, battery is on bottom and can be easily removed/replaced as per steps 7 & 8.
bevrievley - 回复
now how do we FORCE a factory data reset without the admin password?
baily jacoby - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 7,804
