跳转到主内容
加入维修社区 - 创建账户
VTech Little Apps Tablet LED Replacement
你所需要的
    1. VTech Little Apps Tablet LED Replacement, Battery: 步骤 1 中的图像 1,1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      询问修复机器人
      添加评论
    2. VTech Little Apps Tablet LED Replacement: 步骤 2 中的图像 1,1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      询问修复机器人
      添加评论
    1. VTech Little Apps Tablet LED Replacement, Back Cover: 步骤 3 中的图像 1,2 VTech Little Apps Tablet LED Replacement, Back Cover: 步骤 3 中的图像 2,2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      询问修复机器人
      添加评论
    2. VTech Little Apps Tablet LED Replacement: 步骤 4 中的图像 1,2 VTech Little Apps Tablet LED Replacement: 步骤 4 中的图像 2,2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      询问修复机器人
      添加评论
    1. VTech Little Apps Tablet LED Replacement, LED: 步骤 5 中的图像 1,1
      • Unscrew the two 7.3 mm screws using a PH0 driver head.
      • Gently lift the beige circuit board and set aside.
      • Be sure to not damage the wires connecting the circuit board to the motherboard, you are only creating space to work in.
      询问修复机器人
      添加评论
    2. VTech Little Apps Tablet LED Replacement: 步骤 6 中的图像 1,2 VTech Little Apps Tablet LED Replacement: 步骤 6 中的图像 2,2
      • Unscrew three 7.3 mm panhead screws with the PH0 driver.
      • Remove the red-brown washer after removing the screws.
      • Remove the black foam insert and set aside.
      询问修复机器人
      添加评论
    3. VTech Little Apps Tablet LED Replacement: 步骤 7 中的图像 1,1
      • Unscrew the 7.3 mm screw fastening the LED circuit board to the device shell with a PH0 driver head.
      • Be careful when rescrewing circuit boards. Too much pressure or too tight of screws could damage them.
      询问修复机器人
      添加评论
    4. VTech Little Apps Tablet LED Replacement: 步骤 8 中的图像 1,2 VTech Little Apps Tablet LED Replacement: 步骤 8 中的图像 2,2
      • Gently lift both LED circuit board and the white glass light refractor panel away from the device.
      • Separate the LED circuit board and light refractor panel by gently pulling apart. Place the light panel to the side.
      • Skip the next step if you are proceeding with this guide as a part of the Screen Replacement.
      询问修复机器人
      添加评论
    5. VTech Little Apps Tablet LED Replacement: 步骤 9 中的图像 1,1
      • Carefully desolder the LED leads (labeled "R", "+" and "B" on the circuit board) to disconnect the LED from the circuit board.
      • Replace the LED and solder the new connection to the LED circuit board.
      • Refer to the iFixit Soldering Guide for assistance.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 933
