跳转到主内容
加入维修社区 - 创建账户
VTech Baby's Learning Laptop LEDs Replacement
你所需要的
    1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: 步骤 1 中的图像 1,1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      询问修复机器人
      添加评论
    2. VTech Baby's Learning Laptop LEDs Replacement: 步骤 2 中的图像 1,1
      • Remove the battery door.
      • Take out the batteries.
      询问修复机器人
      添加评论
    3. VTech Baby's Learning Laptop LEDs Replacement: 步骤 3 中的图像 1,2 VTech Baby's Learning Laptop LEDs Replacement: 步骤 3 中的图像 2,2
      • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
      询问修复机器人
      添加评论
    4. VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 1,3 VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 2,3 VTech Baby's Learning Laptop LEDs Replacement: 步骤 4 中的图像 3,3
      • With the lid closed, position the device such that the handle is pointing towards you.
      • Using your fingers, gently pry open the cover from the hinge.
      • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
      询问修复机器人
      添加评论
    5. VTech Baby's Learning Laptop LEDs Replacement: 步骤 5 中的图像 1,1
      • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    6. VTech Baby's Learning Laptop LEDs Replacement: 步骤 6 中的图像 1,1
      • Pickup the array by the opening in the center of the board.
      • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
      • Movement of the array will be limited as it is still attached to the main device board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G2
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 36
总计 1,580
