跳转到主内容
加入维修社区 - 创建账户
Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: 步骤 1 中的图像 1,1
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
    询问修复机器人
    添加评论
  2. Using the 3DS's Safe Mode, Updating the System: 步骤 2 中的图像 1,3 Using the 3DS's Safe Mode, Updating the System: 步骤 2 中的图像 2,3 Using the 3DS's Safe Mode, Updating the System: 步骤 2 中的图像 3,3
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
    添加评论
  3. Using the 3DS's Safe Mode: 步骤 3 中的图像 1,1
    • When the update finishes, the console will automatically turn off
    询问修复机器人
    添加评论
结论
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
取消:我没有完成这个指南。
3等其他人完成本指南。
darth mango
于03/13/23注册
3,763 声望
创作了3篇指南
4指南评论
Does this work on old family 3ds?
maxxy waxxy - 回复 分享
Works on every 3ds and 2ds model
darth mango - 回复 分享
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - 回复 分享
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
darth mango - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 108
过去 30 天: 451
总计 16,033
