跳转到主内容
加入维修社区 - 创建账户
Upper Ice Maker Replacement
你所需要的
    1. Upper Ice Maker Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      询问修复机器人
      添加评论
    1. Upper Ice Maker Replacement, Open the doors: 步骤 2 中的图像 1,3 Upper Ice Maker Replacement, Open the doors: 步骤 2 中的图像 2,3 Upper Ice Maker Replacement, Open the doors: 步骤 2 中的图像 3,3
      • Open both refrigerator doors fully.
      询问修复机器人
      添加评论
    1. Upper Ice Maker Replacement, Open the ice maker door: 步骤 3 中的图像 1,3 Upper Ice Maker Replacement, Open the ice maker door: 步骤 3 中的图像 2,3 Upper Ice Maker Replacement, Open the ice maker door: 步骤 3 中的图像 3,3
      • Pull down the latch handle to release the ice maker door.
      • Swing open the ice maker door.
      询问修复机器人
      添加评论
    2. Upper Ice Maker Replacement, Remove the ice bucket: 步骤 4 中的图像 1,3 Upper Ice Maker Replacement, Remove the ice bucket: 步骤 4 中的图像 2,3 Upper Ice Maker Replacement, Remove the ice bucket: 步骤 4 中的图像 3,3
      • Using two hands, lift up the ice bucket slightly to release it.
      • Pull the bottom edge of the ice bucket toward you slightly and remove it.
      询问修复机器人
      添加评论
    3. Upper Ice Maker Replacement, Reassembly notes: 步骤 5 中的图像 1,3 Upper Ice Maker Replacement, Reassembly notes: 步骤 5 中的图像 2,3 Upper Ice Maker Replacement, Reassembly notes: 步骤 5 中的图像 3,3
      • The drive hub notches and drive blade wings must line up before installing the ice bucket.
      • Rotate the ice bucket hub, located on the rear of the ice bucket, with your hand so that the notches will align with the auger motor drive blades.
      询问修复机器人
      添加评论
    1. Upper Ice Maker Replacement, Remove the ice maker assembly screws: 步骤 6 中的图像 1,2 Upper Ice Maker Replacement, Remove the ice maker assembly screws: 步骤 6 中的图像 2,2
      • Use a #2 Philips driver to remove the three 15 mm‑long screws that secure the ice maker assembly to the refrigerator door.
      询问修复机器人
      添加评论
    2. Upper Ice Maker Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 1,3 Upper Ice Maker Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 2,3 Upper Ice Maker Replacement, Reposition the ice maker assembly: 步骤 7 中的图像 3,3
      • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
      • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
      询问修复机器人
      添加评论
    3. Upper Ice Maker Replacement: 步骤 8 中的图像 1,3 Upper Ice Maker Replacement: 步骤 8 中的图像 2,3 Upper Ice Maker Replacement: 步骤 8 中的图像 3,3
      • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
      • Squeeze the connector at the top of the ice maker assembly to release it.
      • Pull the connector straight down to disconnect it.
      询问修复机器人
      添加评论
    4. Upper Ice Maker Replacement, Remove the ice maker assembly: 步骤 9 中的图像 1,1
      • Remove the ice maker assembly.
      询问修复机器人
      添加评论
    1. Upper Ice Maker Replacement, Remove the air duct from the ice maker: 步骤 10 中的图像 1,1
      • Use a Phillips screwdriver to remove the 14.4 mm‑long air duct screw from the side of the ice maker assembly.
      • The air duct gasket partially covers this screw.
      询问修复机器人
      添加评论
    2. Upper Ice Maker Replacement: 步骤 11 中的图像 1,2 Upper Ice Maker Replacement: 步骤 11 中的图像 2,2
      • Remove the air duct.
      询问修复机器人
      添加评论
    3. Upper Ice Maker Replacement, Remove the circuit board cover: 步骤 12 中的图像 1,1
      • Use a Phillips screwdriver to remove the two 32.5 mm‑long screws securing the circuit board cover.
      询问修复机器人
      添加评论
    4. Upper Ice Maker Replacement: 步骤 13 中的图像 1,2 Upper Ice Maker Replacement: 步骤 13 中的图像 2,2
      • Open the circuit board cover.
      • The circuit board cover has wires that must be disconnected before removing the ice maker.
      询问修复机器人
      添加评论
    5. Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: 步骤 14 中的图像 1,2 Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: 步骤 14 中的图像 2,2
      • Squeeze the three-wire connector to release it from the circuit board.
      • Pull the three-wire connector straight out to disconnect it.
      询问修复机器人
      添加评论
    6. Upper Ice Maker Replacement: 步骤 15 中的图像 1,3 Upper Ice Maker Replacement: 步骤 15 中的图像 2,3 Upper Ice Maker Replacement: 步骤 15 中的图像 3,3
      • Squeeze the multi-wire connector with the two orange wires running to the on/off switch.
      • Pull the connector straight out to disconnect it.
      询问修复机器人
      添加评论
    7. Upper Ice Maker Replacement: 步骤 16 中的图像 1,3 Upper Ice Maker Replacement: 步骤 16 中的图像 2,3 Upper Ice Maker Replacement: 步骤 16 中的图像 3,3
      • Use long nose pliers to pull the two spade connectors straight off the on-off switch terminals.
      询问修复机器人
      添加评论
    8. Upper Ice Maker Replacement, Unfasten the ice maker from the back plate: 步骤 17 中的图像 1,1
      • Use a Phillips screwdriver to remove the three 16.5 mm‑long screws securing the ice maker to the back plate.
      询问修复机器人
      添加评论
    9. Upper Ice Maker Replacement, Remove the ice maker from the back plate: 步骤 18 中的图像 1,2 Upper Ice Maker Replacement, Remove the ice maker from the back plate: 步骤 18 中的图像 2,2
      • Lift the ice maker off the back plate and remove it.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
取消:我没有完成这个指南。
Bill Gilbert
于06/30/22注册
40,174 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了56,479篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 432
