跳转到主内容
加入维修社区 - 创建账户
UnBranded UB-15MS10 Back Panel Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. UnBranded UB-15MS10 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
      询问修复机器人
      添加评论
    2. UnBranded UB-15MS10 Back Panel Replacement: 步骤 2 中的图像 1,1
      • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
      询问修复机器人
      添加评论
    3. UnBranded UB-15MS10 Back Panel Replacement: 步骤 3 中的图像 1,2 UnBranded UB-15MS10 Back Panel Replacement: 步骤 3 中的图像 2,2
      • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
      • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
      询问修复机器人
      添加评论
    4. UnBranded UB-15MS10 Back Panel Replacement: 步骤 4 中的图像 1,1
      • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
      • As the gaps open, slide the guitar picks along the sides to separate the panels.
      添加评论
    5. UnBranded UB-15MS10 Back Panel Replacement: 步骤 5 中的图像 1,1
      • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
团队
IUPUI, Team 2-1, Baechle Fall 2015 IUPUI, Team 2-1, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G1
3 名成员
创作了12篇指南
1指南评论
Thanks you, work good for me.
Cesar Alvarez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 1,589
