跳转到主内容
加入维修社区 - 创建账户
Turtle Beach PX22 Microphone Replacement
你所需要的
    1. Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 1,3 Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 2,3 Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 3,3
      • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
      • Use a Philips #00 head screwdriver to remove three 7.1 mm screws around the speaker.
      • The housing will come loose.
      • Gently lift the speaker housing off the ear cup, being careful not to pull on the driver/speaker assembly, which is still connected to a board inside.
      询问修复机器人
      添加评论
    2. Turtle Beach PX22 Microphone Replacement: 步骤 2 中的图像 1,1
      • Remove the 7.1 mm screw with a Phillips #2 screwdriver to gain access to the microphone.
      • You may need to pull the wire with the knot out of the way of the screw.
      询问修复机器人
      添加评论
    3. Turtle Beach PX22 Microphone Replacement: 步骤 3 中的图像 1,1
      • Use a soldering iron to carefully desolder the microphone wire connectors from the board.
      • Take care not to overheat the board or nearby components.
      • Insert the new microphone and solder the wires into the correct positions.
      • Replace the screw that secures the microphone with a Phillips #2 screwdriver.
      • Pull the excess microphone wire back into the speaker housing.
      • Hold the microphone neck so that it does not rotate when screwing.
      询问修复机器人
      添加评论
    4. Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 1,3 Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 2,3 Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 3,3
      • Position the speaker on the headset so that the screw holes line up. It should click into place.
      • Use a Phillips #00 screwdriver to secure the three screws.
      • Replace the ear cushion.
      • Use the plastic opening tool to tuck excess leather inside the headset.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G1
4 名成员
创作了16篇指南
3指南评论
Where do we buy the mic?
Brit B - 回复 分享
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - 回复 分享
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 35
总计 7,337
