跳转到主内容
加入维修社区 - 创建账户
Trio Stealth G4 Battery Replacement
你所需要的
    1. Trio Stealth G4 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
      • Flip your tablet over so that the back panel is facing up.
      询问修复机器人
      添加评论
    2. Trio Stealth G4 Battery Replacement: 步骤 2 中的图像 1,2 Trio Stealth G4 Battery Replacement: 步骤 2 中的图像 2,2
      • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
      • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
      询问修复机器人
      添加评论
    3. Trio Stealth G4 Battery Replacement: 步骤 3 中的图像 1,1
      • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
      • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
      询问修复机器人
      添加评论
    4. Trio Stealth G4 Battery Replacement: 步骤 4 中的图像 1,2 Trio Stealth G4 Battery Replacement: 步骤 4 中的图像 2,2
      • Remove the back panel from the rest of the tablet and set it aside.
      询问修复机器人
      添加评论
    5. Trio Stealth G4 Battery Replacement: 步骤 5 中的图像 1,1
      • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
      询问修复机器人
      添加评论
    1. Trio Stealth G4 Battery Replacement, Battery: 步骤 6 中的图像 1,1
      • Remove the black tape covering the zero insertion force (ZIF) connector that holds down the end of the yellow colored ribbon wire that lies across the battery.
      询问修复机器人
      添加评论
    2. Trio Stealth G4 Battery Replacement: 步骤 7 中的图像 1,3 Trio Stealth G4 Battery Replacement: 步骤 7 中的图像 2,3 Trio Stealth G4 Battery Replacement: 步骤 7 中的图像 3,3
      • Wedge a spudger underneath the black flap on the ZIF connector and flip it up.
      • Once the flap is up, use your fingers to disconnect the end of the ribbon wire from the connector.
      询问修复机器人
      添加评论
    3. Trio Stealth G4 Battery Replacement: 步骤 8 中的图像 1,1
      • Carefully remove the yellow tape from the red and black wires connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. Trio Stealth G4 Battery Replacement: 步骤 9 中的图像 1,1
      • Use the soldering iron to melt away the solder from the motherboard connections.
      • Once the solder is completely removed, pull the wires away from the motherboard.
      询问修复机器人
      添加评论
    5. Trio Stealth G4 Battery Replacement: 步骤 10 中的图像 1,2 Trio Stealth G4 Battery Replacement: 步骤 10 中的图像 2,2
      • Use the spudger to gently dislodge the battery from the tablet.
      • Do not bend the lithium-ion battery. This can cause a fire.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Matt Arnold
于09/22/15注册
607 声望
创作了5篇指南
团队
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G1
4 名成员
创作了30篇指南
1指南评论
trio stealth g4 10.1 v2 tablet replacement battery what battery is that number , please thank you
jone paul - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 5,932
