跳转到主内容
Toshiba Satellite L55t-B5271 Back Panel Replacement
Garrett Garofalo
Garrett Garofalo3 其他贡献者
最后更新于 March 7, 2024
2分钟
简单
This guide will help you remove the back panel of your device. No special skills are required, but you do need to know how to use a Phillips #00 screwdriver.
你所需要的
工具
查看更多...
  1. Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Back Panel Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L55t-B5271 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Back Panel Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L55t-B5271 Back Panel Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L55t-B5271 Back Panel Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: 步骤 4 中的图像 1,3 Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: 步骤 4 中的图像 2,3 Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
结论
团队
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G3
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 493
