跳转到主内容
Toshiba Satellite L305D-S5950 Motherboard Cover Replacement
John Drinkwater
John Drinkwater2 其他贡献者
最后更新于 July 15, 2014
10 - 15 分钟
中等
需要更好的图片
In order to take the motherboard cover off the keyboard needs to be removed.
你所需要的
工具
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 2 中的图像 2,2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 3 中的图像 2,2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: 步骤 5 中的图像 1,2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 6 中的图像 1,1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 7 中的图像 3,3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: 步骤 9 中的图像 1,2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: 步骤 9 中的图像 2,2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: 步骤 10 中的图像 3,3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
结论
团队
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 318
