跳转到主内容
Toshiba Satellite C55-B5200 Keyboard Replacement
Pablo Andrade
Pablo Andrade3 其他贡献者
最后更新于 May 7, 2024
10分钟
困难
Standard Keyboard with 10-key and touchpad with multi-touch control
你所需要的
工具
查看更多...
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
    You only need to remove ONE screw in this step not six since there are only two screws holding the bottom side of the keyboard in place. One of these screws is removed from the bottom case, and the other is inside just to the left of the motherboard in the middle. There is no need to remove the motherboard, hdd and heat sink in order to replace the keyboard in this laptop. Don't know what the author is trying to do here.
    Stallion K - 回复
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
    This is absolutely NOT how you do this step. I've done several of these. You need to use a guitar pick or credit card and start at the bottom clip just to the left of the space bar trying to release that clip then work your way to the right and left releasing the clips. DON'T START AT THE TOP OR SIDES. YOU WILL ONLY BE WASTING YOUR TIME. The top part of this keyboard does not contain clips that can be released. Instead the top contains metal tabs that slide into slots. Each side has one clip, but it's easier to start where I said. Once you release all the plastic clips on the bottom then the one on each side, you can slide the top portion of the keyboard right out. You have to be patient with the plastic clips on the bottom and sides though. Make sure you use a non-marring tool like a plastic guitar pick or a credit card instead of something metal that will just scratch up everything and make it look terrible.
    Stallion K - 回复
结论
2等其他人完成本指南。
Pablo Andrade
于02/14/18注册
1,081 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了22篇指南
1指南评论
gracias por la guía
Mark Puga - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 47
总计 4,101
