跳转到主内容
Toshiba Satellite C55-B5200 Keyboard Replacement
Pablo Andrade
Pablo Andrade3 其他贡献者
最后更新于 May 7, 2024
10分钟
困难
Standard Keyboard with 10-key and touchpad with multi-touch control
你所需要的
工具
查看更多...
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite C55-B5200 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
结论
2等其他人完成本指南。
Pablo Andrade
于02/14/18注册
1,081 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S3G1
4 名成员
创作了22篇指南
1指南评论
gracias por la guía
Mark Puga - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 49
总计 4,095
