跳转到主内容
Toshiba Satellite A665-S5170 Hard Drive Replacement
Chelsea Teague
Chelsea Teague 另一个贡献者
最后更新于 July 1, 2023
2分钟
简单
If your computer is slow, freezes frequently, or displays a blue screen upon starting up, you may need to replace your hard drive. To replace your Toshiba Satellite A665-S5170 hard drive, you will need a Phillips head 0 screwdriver. Remember to treat your hard drive gently when removing it from your computer.
你所需要的
工具
  1. Toshiba Satellite A665-S5170 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the computer upside down so that the bottom of the laptop is facing up.
    • Position the laptop so that you are able to read the words printed on the labels on the bottom of the laptop from left to right, and so that the laptop's hard drive panel is in the upper right-hand corner of the bottom of the computer.
    • Using a Phillip’s head 0 screwdriver, remove the 2mm Phillips head screw on the right side of the cover of the hard drive panel by rotating it counter-clockwise.
  2. Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Insert something thin, such as your nail or a credit card, into the slot on the right side of the cover of the hard drive panel.
    • Pull your finger up to pop off the cover of the hard drive panel.
  3. Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Gently push down on the hard drive with your hand.
    • Still pressing down on the hard drive, move your hand to the right in order to slide the hard drive to the right and to disconnect it from the computer.
  4. Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • To pull out the hard drive, pinch the plastic tab attached to the right of the hard drive with your thumb and index finger.
    • Gently lift the hard drive from the panel by pulling up on the plastic tab.
结论
Chelsea Teague
于10/30/16注册
385 声望
创作了2篇指南
团队
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 1,945
