跳转到主内容
Toshiba NB250-108 KEYBOARD Replacement
Guenter Hildebrandt
Guenter Hildebrandt
最后更新于 December 28, 2017
没有估计
中等
社区贡献指南
你所需要的
  1. Toshiba NB250-108 KEYBOARD Replacement, Remove the battery: 步骤 1 中的图像 1,2 Toshiba NB250-108 KEYBOARD Replacement, Remove the battery: 步骤 1 中的图像 2,2
    • Save your work.
    • Turn off the computer. The LED Power must not light up anymore.
    • Disconnect all cables and devices connected to the computer.
    • Close the screen and place the computer face down as shown in the picture.
    • Slide the safety latch (on the left side of the picture) to the unlocked position (to the left) to activate the release.
    • Slide the battery release (pictured on the right) to the right side and hold it to release the battery and remove the battery from the back of the computer.
  2. Toshiba NB250-108 KEYBOARD Replacement, Remove keyboard: 步骤 2 中的图像 1,3 Toshiba NB250-108 KEYBOARD Replacement, Remove keyboard: 步骤 2 中的图像 2,3 Toshiba NB250-108 KEYBOARD Replacement, Remove keyboard: 步骤 2 中的图像 3,3
    • Remove the 5 marked screws and then turn the device over and open the screen.
    • First, we remove the cover of the Einschalteinheit by levering each other with a spatula to the left and right.
    • Grasp the keyboard at the top and on the left side start to lever out the keyboard with a spatula. Repeat this procedure on the right.
  3. Toshiba NB250-108 KEYBOARD Replacement, Remove keyboard cable: 步骤 3 中的图像 1,1
    • Gently push the keyboard towards the screen until the keyboard cable connector becomes visible.
    • Hold the keyboard in this position with one hand and use the other hand and pointed tweezers to open the black retaining clips by sliding them in the direction of the ribbon cable.
    • Now the ribbon cable can be pulled out of the holder.
    • Place the keyboard securely on its work surface.
结论
Repeat the steps in order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Guenter Hildebrandt
于12/16/15注册
1,141 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 574
