简介
If the device's screen is experiencing problems in its visuals, such as discoloration or image distortion, your device may need a display replacement. Otherwise, if the device does not register touches then you may want to replace the digitizer. Confirm the device is powered off before starting the disassembly.
你所需要的
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
在这个步骤中使用的工具:Tweezers$4.99
Remove the microphone on the left side of the screen casing using tweezers.
6等其他人完成本指南。
