跳转到主内容
加入维修社区 - 创建账户
The Claw Music Player Replacement
你所需要的
  1. The Claw Music Player Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Place The Claw in upright position with controls facing you.
    询问修复机器人
    添加评论
  2. The Claw Music Player Replacement: 步骤 2 中的图像 1,1
    • Gently flip The Claw machine upside down with the controls facing you.
    询问修复机器人
    添加评论
  3. The Claw Music Player Replacement: 步骤 3 中的图像 1,1
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
    询问修复机器人
    添加评论
  4. The Claw Music Player Replacement: 步骤 4 中的图像 1,2 The Claw Music Player Replacement: 步骤 4 中的图像 2,2
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
    询问修复机器人
    添加评论
  5. The Claw Music Player Replacement: 步骤 5 中的图像 1,1
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: 如何焊接和拆焊.
    询问修复机器人
    添加评论
  6. The Claw Music Player Replacement, Music Player: 步骤 6 中的图像 1,1
    • Turn the bottom panel over to have easy access to the music player.
    询问修复机器人
    添加评论
  7. The Claw Music Player Replacement: 步骤 7 中的图像 1,1
    • Locate the music player inside the device.
    • Be sure you have turned the device off and removed the batteries before you reach into the machine with your hands or any metal tools.
    询问修复机器人
    添加评论
  8. The Claw Music Player Replacement: 步骤 8 中的图像 1,1
    • Locate the screws that hold the music player in place and remove them with a Phillips screwdriver.
    • The complete removal of the music player requires the cutting of existing wires and soldering new wires to the new player. For help with soldering reference: 如何焊接和拆焊
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alain Pierre
于03/22/16注册
1,188 声望
创作了9篇指南
团队
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G8
3 名成员
创作了18篇指南
2指南评论
I only cut one of the wires connecting to the soundbox and the sound completely stopped. Im not too upset bc that was my goal, but I did want to see how much quieter it would get.
Also, to anybody who might have the same problem as me: After I cut the sound wire the machine would not turn on at all and I was very confused. Turns out another wire (black wire connecting the circuit board to the + on the battery pack) came loose. I stripped it a bit and got it back in place (albeit with a piece of tape) and it turns on fine now. So use more caution than you think you need when handling the floor of the machine, at least when the wires are still connected.
anitho - 回复 分享
Current problems:
1) left/right joystick not responding, but after a good jiggle its back to functioning again. Same happened with the machine not powering on again (this was after fixing the wire), but turn it upside down and back, and its working. And once everythings working, when you move the joysticks the red light in the prize chute flickers a bit. If i had to put money on it id say its the wire being attached to the battery pack with a $@$*!& little piece of tape, but ill try soldiering it back so i'll see if that fixes it
2) up/down function of the claw often gets stuck with a grinding sound. Releasing the joystick back to neutral and trying again usually gets it working, but id still like to fix it. Im pretty sure this is more of a mechanical issue than electric, but i still don't really know what the problem could be
I’ll update my comment if I find the solution to these issues. But be wary that im currently a software undergrad, not electrical/mech, so i honestly dont rlly know what Im talking abt lol
anitho - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 37
总计 2,371
