跳转到主内容
加入维修社区 - 创建账户
Tagital T7X Battery Replacement
你所需要的
    1. Tagital T7X Battery Replacement, Case: 步骤 1 中的图像 1,3 Tagital T7X Battery Replacement, Case: 步骤 1 中的图像 2,3 Tagital T7X Battery Replacement, Case: 步骤 1 中的图像 3,3
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
      询问修复机器人
      添加评论
    1. Tagital T7X Battery Replacement, Battery: 步骤 2 中的图像 1,2 Tagital T7X Battery Replacement, Battery: 步骤 2 中的图像 2,2
      • Follow the attached wires to the positive and negative connections.
      询问修复机器人
      添加评论
    2. Tagital T7X Battery Replacement: 步骤 3 中的图像 1,3 Tagital T7X Battery Replacement: 步骤 3 中的图像 2,3 Tagital T7X Battery Replacement: 步骤 3 中的图像 3,3
      • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
      • Touch the tip of the soldering iron to the solder connecting the negative wire.
      • Pull back on the wire with the iron in place, removing it from the hot solder.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
      • Repeat this step for the positive wire.
      询问修复机器人
      添加评论
    3. Tagital T7X Battery Replacement: 步骤 4 中的图像 1,3 Tagital T7X Battery Replacement: 步骤 4 中的图像 2,3 Tagital T7X Battery Replacement: 步骤 4 中的图像 3,3
      • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
      • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G1
4 名成员
创作了12篇指南
1指南评论
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
Melanie Bouy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 28
总计 1,400
