跳转到主内容
加入维修社区 - 创建账户
TOZO HT2 Battery Replacement
你所需要的
  1. TOZO HT2 Battery Replacement, Ear Pad: 步骤 1 中的图像 1,3 TOZO HT2 Battery Replacement, Ear Pad: 步骤 1 中的图像 2,3 TOZO HT2 Battery Replacement, Ear Pad: 步骤 1 中的图像 3,3
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Battery Replacement: 步骤 2 中的图像 1,3 TOZO HT2 Battery Replacement: 步骤 2 中的图像 2,3 TOZO HT2 Battery Replacement: 步骤 2 中的图像 3,3
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the four Phillips screws securing the speaker housing.
  4. TOZO HT2 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to gently pry the battery out of its housing.
    • Do not use a metal spudger as demonstrated in the photo. Take care not to puncture or bend the battery.
  5. TOZO HT2 Battery Replacement: 步骤 5 中的图像 1,1
    • Take wire cutters and carefully snip the battery free, cutting as close to the battery as possible.
  6. TOZO HT2 Battery Replacement: 步骤 6 中的图像 1,1
    • Solder the wires onto the new battery.
    • HANDLE WITH CARE: Soldering iron can be VERY hot (reaching temperatures up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated area and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 59
总计 626
