跳转到主内容
TI-84 Plus Silver Edition Main Battery Replacement
Mary Prescott
Mary Prescott6 其他贡献者
最后更新于 December 6, 2022
5分钟
简单
If your TI-84 Plus Silver Edition is not turning on, you may want to replace the main batteries. These are the main power sources for the device and if they have died, the power will not work.
  1. TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: 步骤 1 中的图像 1,3 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: 步骤 1 中的图像 2,3 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: 步骤 1 中的图像 3,3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Main Battery Replacement: 步骤 2 中的图像 1,1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
    Removing these batteries and the back up battery will clear the calculators memory.
    Aaron Rueppel - 回复
结论
4等其他人完成本指南。
Mary Prescott
于10/20/13注册
560 声望
撰写一个指南
团队
Cal Poly, Team 11-34, Amido Fall 2013 Cal Poly, Team 11-34, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G34
4 名成员
创作了6篇指南
一条评论
cool i can math now thank
Thomas Maloney - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 10,332
