跳转到主内容
加入维修社区 - 创建账户
System76 Serval WS Cooling Fan Replacement
你所需要的
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
    询问修复机器人
    添加评论
  2. System76 Serval WS Cooling Fan Replacement: 步骤 2 中的图像 1,2 System76 Serval WS Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
    询问修复机器人
    添加评论
  3. System76 Serval WS Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
    询问修复机器人
    添加评论
  4. System76 Serval WS Cooling Fan Replacement: 步骤 4 中的图像 1,2 System76 Serval WS Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    询问修复机器人
    添加评论
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Oliver Anderson
于03/26/19注册
289 声望
创作了3篇指南
团队
1指南评论
What model of fan would one buy to replace this?
CrustyTrombone - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 1,307
