跳转到主内容
加入维修社区 - 创建账户
SuperSonic Matrix Mid SC-999 Battery Replacement
你所需要的
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 2 中的图像 1,1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      询问修复机器人
      添加评论
    3. SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 3 中的图像 1,2 SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 3 中的图像 2,2
      • Lift the back cover from the body of the device to expose the internal components.
      询问修复机器人
      添加评论
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 步骤 4 中的图像 1,3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 步骤 4 中的图像 2,3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: 步骤 4 中的图像 3,3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      询问修复机器人
      添加评论
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 5 中的图像 1,3 SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 5 中的图像 2,3 SuperSonic Matrix Mid SC-999 Battery Replacement: 步骤 5 中的图像 3,3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G1
4 名成员
创作了81篇指南
1指南评论
Link to the soldering technique guide!
Josh Lewis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 39
总计 2,734
