跳转到主内容
Steam Deck OLED View Button Replacement
你所需要的
  1. Steam Deck OLED View Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 1,3 Steam Deck OLED View Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 2,3 Steam Deck OLED View Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 3,3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED View Button Replacement, Remove the back cover screws: 步骤 2 中的图像 1,2 Steam Deck OLED View Button Replacement, Remove the back cover screws: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED View Button Replacement, Unclip a handle: 步骤 3 中的图像 1,3 Steam Deck OLED View Button Replacement, Unclip a handle: 步骤 3 中的图像 2,3 Steam Deck OLED View Button Replacement, Unclip a handle: 步骤 3 中的图像 3,3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED View Button Replacement, Unclip the top and bottom edges: 步骤 4 中的图像 1,3 Steam Deck OLED View Button Replacement, Unclip the top and bottom edges: 步骤 4 中的图像 2,3 Steam Deck OLED View Button Replacement, Unclip the top and bottom edges: 步骤 4 中的图像 3,3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED View Button Replacement, Remove the back cover: 步骤 5 中的图像 1,3 Steam Deck OLED View Button Replacement, Remove the back cover: 步骤 5 中的图像 2,3 Steam Deck OLED View Button Replacement, Remove the back cover: 步骤 5 中的图像 3,3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED View Button Replacement, Disconnect the battery: 步骤 6 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the battery: 步骤 6 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the battery: 步骤 6 中的图像 3,3
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 7 中的图像 1,2 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 7 中的图像 2,2
    • During disassembly, skip the next four steps.
    • During reassembly:
    • Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
    • Reconnect the interconnect cable ZIF connector.
  8. Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 8 中的图像 1,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 8 中的图像 2,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 8 中的图像 3,3
    • Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
  9. Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 9 中的图像 1,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 9 中的图像 2,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 9 中的图像 3,3
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
    • Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
    • Be careful not to crease or strain the cable.
  10. Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 10 中的图像 1,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 10 中的图像 2,3 Steam Deck OLED View Button Replacement, Reassembly instructions: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • During reassembly, follow this step and the above four steps to reconnect the battery.
    • In this reassembly step, you'll disconnect the interconnect cable to free the motherboard shield.
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    • The pull tab may be labelled C‑R.
  11. Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 11 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 11 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the point of a spudger to flip up the small locking flap on the left thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
  12. Steam Deck OLED View Button Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a spudger to flip up the small white locking flap on the left button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑L.
  13. Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 13 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 13 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the left thumbstick: 步骤 13 中的图像 3,3
    • Flip up the small black locking flap on the left thumbstick cable ZIF connector.
    • The pull tab on this connector may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
  14. Steam Deck OLED View Button Replacement, Disconnect the D-pad: 步骤 14 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the D-pad: 步骤 14 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the D-pad: 步骤 14 中的图像 3,3
    • Flip up the small locking flap on the D‑pad ZIF connector, located in the top right corner.
    • The pull tab on this connector may be labeled DPAD.
  15. Steam Deck OLED View Button Replacement, Disconnect the touchpad board: 步骤 15 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the touchpad board: 步骤 15 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the touchpad board: 步骤 15 中的图像 3,3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the previous one.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Lift the connector until its arms are free and slide it straight out to disconnect it.
  16. Steam Deck OLED View Button Replacement, Disconnect the left haptics: 步骤 16 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the left haptics: 步骤 16 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the left haptics: 步骤 16 中的图像 3,3
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the right side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
  17. Steam Deck OLED View Button Replacement, Disconnect the left touchpad: 步骤 17 中的图像 1,3 Steam Deck OLED View Button Replacement, Disconnect the left touchpad: 步骤 17 中的图像 2,3 Steam Deck OLED View Button Replacement, Disconnect the left touchpad: 步骤 17 中的图像 3,3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the haptics connector.
  18. Steam Deck OLED View Button Replacement, Remove the left button board screws: 步骤 18 中的图像 1,1
    • Use your T6 Torx driver to remove the four screws securing the left button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
  19. Steam Deck OLED View Button Replacement, Remove the left button board: 步骤 19 中的图像 1,3 Steam Deck OLED View Button Replacement, Remove the left button board: 步骤 19 中的图像 2,3 Steam Deck OLED View Button Replacement, Remove the left button board: 步骤 19 中的图像 3,3
    • Insert the point of your spudger between the bottom right corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the five cables become trapped underneath the button board as you lay it into place.
  20. Steam Deck OLED View Button Replacement, Remove the left thumbstick screws: 步骤 20 中的图像 1,2 Steam Deck OLED View Button Replacement, Remove the left thumbstick screws: 步骤 20 中的图像 2,2
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
    • During reassembly, hold the Steam Deck OLED off your work surface so it doesn't rest on your thumbstick as you tighten the screws.
  21. Steam Deck OLED View Button Replacement, Remove the left thumbstick: 步骤 21 中的图像 1,3 Steam Deck OLED View Button Replacement, Remove the left thumbstick: 步骤 21 中的图像 2,3 Steam Deck OLED View Button Replacement, Remove the left thumbstick: 步骤 21 中的图像 3,3
    • Grip the edges of the thumbstick board and rotate it counterclockwise to clear the trigger.
    • Remove the thumbstick.
  22. Steam Deck OLED View Button Replacement, Remove the left trigger: 步骤 22 中的图像 1,3 Steam Deck OLED View Button Replacement, Remove the left trigger: 步骤 22 中的图像 2,3 Steam Deck OLED View Button Replacement, Remove the left trigger: 步骤 22 中的图像 3,3
    • The left trigger is on your right-hand side when working on the Steam Deck OLED, as it's laying upside down.
    • The trigger clips into place on two pegs on the frame, which double as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Use your fingers to push the trigger toward the left as you wedge the spudger between the clip and the peg.
    • Use your spudger to pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the right peg first. Once in place, push down on the trigger to latch the left peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  23. Steam Deck OLED View Button Replacement, Remove the left bumper assembly screws: 步骤 23 中的图像 1,1
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the left bumper assembly.
  24. Steam Deck OLED View Button Replacement, Remove the left bumper assembly: 步骤 24 中的图像 1,3 Steam Deck OLED View Button Replacement, Remove the left bumper assembly: 步骤 24 中的图像 2,3 Steam Deck OLED View Button Replacement, Remove the left bumper assembly: 步骤 24 中的图像 3,3
    • Grip the left arm of the bumper assembly and lift it off its alignment pegs.
    • Slide the assembly to the left to clear the tab on the right edge of the frame.
    • Remove the assembly.
    • The D-pad and view buttons membrane might stay stuck to the underside of the bumper bracket. If so, remove it.
    • During reassembly, line up the bumper bracket with the alignment posts in the frame as you set it into place.
  25. Steam Deck OLED View Button Replacement, Remove the buttons membrane: 步骤 25 中的图像 1,2 Steam Deck OLED View Button Replacement, Remove the buttons membrane: 步骤 25 中的图像 2,2
    • If the D-pad and view buttons membrane stayed on the bumper bracket, skip this step.
    • Remove the D-pad and view button membrane from the frame.
  26. Steam Deck OLED View Button Replacement, Remove the view button: 步骤 26 中的图像 1,2 Steam Deck OLED View Button Replacement, Remove the view button: 步骤 26 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the view button.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
另外一个人完成了本指南。
Clay Eickemeyer
于09/19/22注册
96,090 声望
创作了466篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了15,932篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 59
总计 1,037
