简介
使用本指南更换 Steam Deck 中的左侧肩键 (L1)。
在您开始之前,请完全关闭电源并从您的 Steam Deck 上拔下所有线缆。请记住在维修设备时遵循一般静电放电 (ESD) 安全程序。
请记住:在维修设备时,请遵循一般 静电放电(ESD)安全程序 。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
用十字螺丝刀拆卸固定后盖的 8 颗螺丝:
四个 9.5 毫米长的粗螺纹螺丝
四个 5.8 毫米长的细螺纹螺丝
如果任何接口 被胶带覆盖,请使用镊子将其取下。
使用撬棒的尖端撬起按钮电路板排线与 ZIF 接口上的锁扣。用镊子将排线从接口中拔出。
断开十字键排线。
断开触摸板的电路板排线。
断开触摸板排线。
要重新组装您的设备,请按相反顺序按照说明进行操作。
将您的电子垃圾送到 R2 或 e-Stewards 认证的回收商。
维修未能解决问题?尝试一些基本故障排除,或向我们的 Steam Deck 回答社区寻求帮助。
16等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
13条评论
All good! but you are missing the last step as you will need to replace the Dpad contacts and place them on the new bumper.
This part is not available in Canada, I've seen your product advertised all over the tech industry, but this part is not available to ship to Canada, that's too bad, I would have purchased the repair kit along with this part, I guess I'm stuck with the rma process. I guess right to repair is still very broken.
Just so others are aware, I haven't seen the Left button board or the Right button board available for purchase from Ifixit just yet. I just took apart my deck having ordered a left bumper replacement set thinking this would fix my issue, it will not. The issue is the switch itself that is attached to the Left Button Board
