简介
使用本指南来更换 Steam Deck 上的左摇杆。摇杆杆体和底座是一个整体,你需要将整个摇杆模块进行更换。尽管过程几乎相同,你可以 在这 找到右摇杆的更换流程。
维修设备时遵循常规的。静电放电 (ESD) 安全程序
更换摇杆后需要进行校准才能正常工作。点击 这里 以阅读如何执行此操作。
注意:每个 Steam Deck 都可能会使用一到两种不同型号的摇杆,型号A 或 型号B。尽管他们近乎一致,启用电容触控功能需要使用匹配型号的摇杆。为了确认你需要哪种型号的摇杆,在 Steam Deck 中进入“设置 → 系统”,并检查你的 Steam Deck 控制器 ID 。如果控制器 ID 以 “MEDA” 开头,则设备需要 型号A 的摇杆;如果控制器 ID 以 “MHDA” 开头,则设备需要 型号B 的摇杆。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
用十字螺丝刀拆卸固定后盖的 8 颗螺丝:
四个 9.5 毫米长的粗螺纹螺丝
四个 5.8 毫米长的细螺纹螺丝
如需重新组装你的设备,请遵照这些说明进行反向操作。
请把你的电子垃圾送到 R2或e-Stewards认证的回收处 进行回收处理。
维修结果未达预期?尝试一下 基础故障排除流程 ,或者向 Steam Deck 社区 寻求帮助。
26等其他人完成本指南。
由衷感谢以下译者:
90%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8条评论
Requires a PH#00 not a #0
NoggleFrap - 回复
#0 worked best on the analog sticks for me. #1 for the external case screws. I've heard to always use the size with the snuggest fit in a screw to prevent striping the heads. Considering I only have these screws and no replacements. I'll opt to use the biggest bit that fits.
You need to start offering the ribbon cables, as they are pretty fragile.
I feel like my steam deck was partially made anti-repair, there was a glue like seal blocking the soldering iron from reaching the solder pad on my left joystick specifically, and the screw hidden by the tape on the shield would not unscrew even though my iFixit screwdriver worker for all the others fine and now I'm pretty sure the head is stripped I even tried a super glue hack a few times and in each case the glue gave before the screw did. I was still able to just barely access the battery connector, but reconnecting it is more work than I'd want.
I wonder if anyone else is seeing odd stuff like this...
Someone should ask valve why their sticks are so clicky. I’ve had multiple sticks all click in in the 6 and 8 positions but only on the left side. I’m tired of it so I’m gonna stop replacing it, after going through 5 sticks if you count my RMA for haptic issues, all left sticks have had this issue.
