跳转到主内容
加入维修社区 - 创建账户
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
你所需要的
  1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: 步骤 1 中的图像 1,2 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: 步骤 1 中的图像 2,2
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    询问修复机器人
    添加评论
  2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: 步骤 2 中的图像 1,1
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
    询问修复机器人
    添加评论
  3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 步骤 3 中的图像 1,3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 步骤 3 中的图像 2,3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: 步骤 3 中的图像 3,3
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
    询问修复机器人
    添加评论
  4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 步骤 4 中的图像 1,3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 步骤 4 中的图像 2,3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: 步骤 4 中的图像 3,3
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
    询问修复机器人
    添加评论
  5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: 步骤 5 中的图像 1,1
    • On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
    • Need Help Soldering? Check out 如何焊接和拆焊 for tips.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 的会员
USFT-BROWN-F14S4G5
3 名成员
创作了12篇指南
1指南评论
Where do you get the replacement parts?
clsutliff - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 791
