跳转到主内容
加入维修社区 - 创建账户
Speaker Unit Replacement
你所需要的
    1. Speaker Unit Replacement, Exterior Housing: 步骤 1 中的图像 1,3 Speaker Unit Replacement, Exterior Housing: 步骤 1 中的图像 2,3 Speaker Unit Replacement, Exterior Housing: 步骤 1 中的图像 3,3
      在这个步骤中使用的工具:
      iOpener
      $24.95
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      询问修复机器人
      添加评论
    1. Speaker Unit Replacement, Speaker Unit: 步骤 2 中的图像 1,1
      • Remove these eight 9 mm screws using a Phillips #2 driver.
      询问修复机器人
      添加评论
    2. Speaker Unit Replacement: 步骤 3 中的图像 1,1
      • Carefully lift the cover off. It may be a little sticky from glue.
      询问修复机器人
      添加评论
    3. Speaker Unit Replacement: 步骤 4 中的图像 1,1
      • Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
      询问修复机器人
      添加评论
    4. Speaker Unit Replacement: 步骤 5 中的图像 1,1
      • Caution: the speaker is fitted quite snug. it may take a bit of effort to remove. However, be careful not to pull too hard as you may accidentally pull on the wires once the speaker unit is free.
      • Hold the speaker by its cylindrical frame and cautiously lift it away from the rest of the device.
      询问修复机器人
      添加评论
    5. Speaker Unit Replacement: 步骤 6 中的图像 1,1
      • De-solder the existing soldered connections and remove the speaker from the rest of the device.
      • Insert and solder in a working speaker of the same model. Make sure the points where the wire ends connected are consistent with the old speakers.
      • Note: If you notice that a wire is disconnected, this may be the cause of your problems. Re-solder the connection to fix it.
      • You can refer to iFixit's guide or this informative video for more information on soldering.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jerrell
于04/23/14注册
730 声望
创作了7篇指南
团队
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G50
4 名成员
创作了48篇指南
1指南评论
Good afternoom, my name is vladimir and i ‘m interested both speakers, where i could fi nd them to replace in my ihome? Could you help me?
Vladinir reyes - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 1,459
