跳转到主内容
Sony Xperia Z3 Dual Front Camera Replacement
Sophia
Sophia3 其他贡献者
最后更新于 June 1, 2021
没有估计
中等
社区贡献指南
This is the replacement guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 front camera.
你所需要的
工具
查看更多...
  1. Sony Xperia Z3 Dual Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,1
    • Power off the phone and remove two SIM card trays before replacement.
  2. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 2 中的图像 3,3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 3 中的图像 1,1
    • Remove back cover carefully and avoid cracking the glass.
  4. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 4 中的图像 3,3
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  5. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 5 中的图像 1,1
    • Remove screws at first.
  6. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 6 中的图像 3,3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 7 中的图像 3,3
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  8. Sony Xperia Z3 Dual Front Camera Replacement: 步骤 8 中的图像 1,2 Sony Xperia Z3 Dual Front Camera Replacement: 步骤 8 中的图像 2,2
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
结论
2等其他人完成本指南。
Sophia
于03/25/14注册
43,861 声望
创作了62篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,389
