跳转到主内容
Sony Xperia Z2 Logic Board Replacement
ZFix
ZFix
最后更新于 August 26, 2017
15 - 25 分钟
中等
社区贡献指南
Sony Xperia Z2 (D6502, D6503, and D6543) - How to replace the Logic Board (Main Board).
Please SUBSCRIBE to my channel ツ
你所需要的
工具
  • Tesa 61395 Tape
    Tesa 61395 Tape
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
查看更多...
视频概述
  1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement: 步骤 2 中的图像 3,3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Logic Board Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Logic Board Replacement: 步骤 3 中的图像 2,2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Battery: 步骤 4 中的图像 3,3
  5. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: 步骤 5 中的图像 3,3
    • Unscrew the screw and remove the Wi-Fi Antenna.
  6. Sony Xperia Z2 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,2 Sony Xperia Z2 Logic Board Replacement, Logic Board: 步骤 6 中的图像 2,2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  7. Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z2 Logic Board Replacement: 步骤 7 中的图像 3,3
结论
19等其他人完成本指南。
ZFix
于12/09/13注册
194,222 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,672篇指南
3指南评论
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - 回复
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander -
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 18,684
