Sony Xperia Z Ultra Headphone Jack Replacement
简介
转到步骤 1If your device is not recognizing any headset you plug in, and performing a software repair did not fix this problem, replacing the headphone jack may solve this problem.
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
Push the red stopper of the headphone jack connection through the plastic tunnel with the spudger.
While holding the back end of the headphone jack connection, grasp the headphone jack connection with the pair of tweezers and guide it through the plastic tunnel.
Remove the headphone jack connection from the device.
2等其他人完成本指南。
