跳转到主内容
加入维修社区 - 创建账户
Sony Vaio PCG-F420 Keyboard Replacement
你所需要的
    1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • The battery is located on the left side of the laptop, as shown by the red circle.
      • Make sure the laptop is disconnected and turned completely off.
      询问修复机器人
      添加评论
    2. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 2 中的图像 1,1
      • Remove the battery by following these steps.
      • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
      • The battery can now be removed by pulling it.
      询问修复机器人
      添加评论
    1. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
      • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
      询问修复机器人
      添加评论
    2. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 4 中的图像 1,1
      • Unlock the cover between the keyboard and screen.
      • Gently slide it to the right and lift it up.
      • Exercise caution to avoid excessive force, as wires are connected.
      • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
      询问修复机器人
      添加评论
    3. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 5 中的图像 1,1
      • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
      • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
      询问修复机器人
      添加评论
    4. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 6 中的图像 1,1
      • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
      询问修复机器人
      添加评论
    5. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Carefully unplug the ribbon cable using a pair of tweezers.
      • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
      询问修复机器人
      添加评论
    6. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 8 中的图像 1,2 Sony Vaio PCG-F420 Keyboard Replacement: 步骤 8 中的图像 2,2
      • Now, pull on the ribbon cable, and it will detach from the motherboard.
      • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
      询问修复机器人
      添加评论
    7. Sony Vaio PCG-F420 Keyboard Replacement: 步骤 9 中的图像 1,1
      • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G77
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 40
总计 2,983
