跳转到主内容
Sony PlayStation 3D Display Rear Case Replacement
Tia McNaughton
Tia McNaughton8 其他贡献者
最后更新于 August 24, 2018
5分钟
简单
更好的介绍
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Sony PlayStation 3D Display Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 Sony PlayStation 3D Display Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Rear Case Replacement: 步骤 2 中的图像 1,3 Sony PlayStation 3D Display Rear Case Replacement: 步骤 2 中的图像 2,3 Sony PlayStation 3D Display Rear Case Replacement: 步骤 2 中的图像 3,3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Rear Case Replacement: 步骤 3 中的图像 1,2 Sony PlayStation 3D Display Rear Case Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Rear Case Replacement: 步骤 4 中的图像 1,3 Sony PlayStation 3D Display Rear Case Replacement: 步骤 4 中的图像 2,3 Sony PlayStation 3D Display Rear Case Replacement: 步骤 4 中的图像 3,3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
结论
4等其他人完成本指南。
Tia McNaughton
于10/01/15注册
379 声望
创作了3篇指南
团队
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G16
4 名成员
创作了8篇指南
1指南评论
I got a used display that for some reason came with no screws on the back panel. Can you tell me exactly what type those 6x6mm and 6x8mm screws are? Especially wary since you said the thread sizes are different
Kodi Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 46
总计 2,893
