跳转到主内容
Sony PlayStation 3D Display 3D Sync Transmitter Replacement
Tia McNaughton
Tia McNaughton7 其他贡献者
最后更新于 August 24, 2018
20分钟
中等
This repair might be needed if your 3D glasses will not connect to your Sony PlayStation 3D Display.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: 步骤 1 中的图像 1,2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 2 中的图像 1,3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 2 中的图像 2,3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 2 中的图像 3,3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 3 中的图像 1,2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 4 中的图像 1,3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 4 中的图像 2,3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 4 中的图像 3,3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: 步骤 5 中的图像 1,2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: 步骤 5 中的图像 2,2
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws that hold the 3D Sync Transmitter in place.
  6. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 6 中的图像 1,1
    • Carefully pry off the 3D Sync Transmitter with the plastic opening tool.
    • Use the plastic opening tool to pry at both ends and not from the center as to avoid breaking the 3D Sync Transmitter.
  7. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 7 中的图像 1,2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: 步骤 7 中的图像 2,2
    • Pry the tab slightly up with your thumbnail and pull the connector away from the board.
结论
2等其他人完成本指南。
Tia McNaughton
于10/01/15注册
379 声望
创作了3篇指南
团队
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 12
总计 2,424
