跳转到主内容
Sony ICF-CS15iP Disassembly
Adrian Lopez
Adrian Lopez 另一个贡献者
最后更新于 January 12, 2023
40分钟 - 3小时
中等
不正确的工具
标记错误
社区贡献指南
This is a complete tear down of the Sony ICF-CS15iP
精选文档
  1. Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: 步骤 1 中的图像 1,2 Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: 步骤 1 中的图像 2,2
    • All of these damned screws are approx. a PH1 size.
  2. Sony ICF-CS15iP Disassembly, Remove back and base covers.: 步骤 2 中的图像 1,3 Sony ICF-CS15iP Disassembly, Remove back and base covers.: 步骤 2 中的图像 2,3 Sony ICF-CS15iP Disassembly, Remove back and base covers.: 步骤 2 中的图像 3,3
    • Pull on the back to ease it off, and there will be some wires that will need to be disconnected. (Green circled wire not necessary to remove but recommended)
  3. Sony ICF-CS15iP Disassembly, Remove power and antenna board.: 步骤 3 中的图像 1,1
    • Unfasten the 4 screws holding in the board.
  4. Sony ICF-CS15iP Disassembly, Remove display.: 步骤 4 中的图像 1,2 Sony ICF-CS15iP Disassembly, Remove display.: 步骤 4 中的图像 2,2
    • Remove the following screws:
  5. Sony ICF-CS15iP Disassembly, Remove dock: 步骤 5 中的图像 1,1
    • Remove the following screws and be careful with the dock connector, as it has springs that can fly to oblivion.
  6. Sony ICF-CS15iP Disassembly, Remove speaker assembly.: 步骤 6 中的图像 1,1
  7. Sony ICF-CS15iP Disassembly, Take a break (optional): 步骤 7 中的图像 1,1
    • I chose to eat pretzels, you can have a 10 course meal prepared by Gordon Ramsay
  8. Sony ICF-CS15iP Disassembly, Remove speakers.: 步骤 8 中的图像 1,1
    • These are some good 4 ohm 5 watt speakers.
  9. Sony ICF-CS15iP Disassembly, Remove top buttons.: 步骤 9 中的图像 1,1
    • My specific board has some damage from the previous owner, and I only made it worse lol.
  10. Sony ICF-CS15iP Disassembly, Remove rear buttons.: 步骤 10 中的图像 1,1
    • This is definitely all the screws that need to be unfastened.
    • I used a PH1 and PH0 screwdriver.
结论
另外一个人完成了本指南。
附加文件
Adrian Lopez
于01/14/21注册
527 声望
创作了3篇指南
1指南评论
Buen día y muchas gracias por tomarse el tiempo de documentar el proceso de desarmar un CS15iPN. Tengo una pregunta por favor: ¿Cómo pudo desconectar los ribbons (que se observan en la foto del paso 4) de sus conectores en la tarjeta? Yo desarmé mi equipo y no me atreví a desconectar los ribbons porque me parecía que estaban "soldados" permanentemente en los conectores.
Luis - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 521
