跳转到主内容
Sony Cyber-shot DSC-W730 Flash Capacitor Replacement
Douglas Howe
Douglas Howe4 其他贡献者
最后更新于 February 5, 2021
10分钟
简单
Once you have removed the cover the capacitor (a black cylinder that has 330v capacity) will be attached to the circuit board by a thin ribbon. Be careful with the ribbon.
你所需要的
工具
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Removing the Case: 步骤 1 中的图像 3,3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 2 中的图像 3,3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 3 中的图像 2,2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 4 中的图像 2,2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement: 步骤 5 中的图像 3,3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Capacitor Replacement, Flash Capacitor: 步骤 6 中的图像 3,3
    • Lift the capacitor out and gently pull it away from the control board to unplug the ribbon attached to the side of the circuit board. Be careful not to bend the ribbon.
结论
Douglas Howe
于01/08/15注册
510 声望
创作了4篇指南
团队
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 29
总计 843
