跳转到主内容
加入维修社区 - 创建账户
Sony BDP-BX320 Optical Drive Replacement
你所需要的
    1. Sony BDP-BX320 Optical Drive Replacement, Outer Case: 步骤 1 中的图像 1,1
      • Power off and unplug the device from any power source.
      • Place the Blue-ray player on a clean, stable surface.
      询问修复机器人
      添加评论
    2. Sony BDP-BX320 Optical Drive Replacement: 步骤 2 中的图像 1,2 Sony BDP-BX320 Optical Drive Replacement: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      Magnetic Project Mat
      $19.95
      • If preferred, use the Magnetic Mat to organize screws.
      • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
      • Slide the back section of the top case off the device.
      询问修复机器人
      添加评论
    3. Sony BDP-BX320 Optical Drive Replacement: 步骤 3 中的图像 1,3 Sony BDP-BX320 Optical Drive Replacement: 步骤 3 中的图像 2,3 Sony BDP-BX320 Optical Drive Replacement: 步骤 3 中的图像 3,3
      • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
      询问修复机器人
      添加评论
    4. Sony BDP-BX320 Optical Drive Replacement: 步骤 4 中的图像 1,1
      • Slide off the front section of the top case to expose the internal components.
      添加评论
    1. Sony BDP-BX320 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,1
      • Locate the optical drive, which is positioned next to the main board and connected by a wide ZIF connector ribbon cable.
      询问修复机器人
      添加评论
    2. Sony BDP-BX320 Optical Drive Replacement: 步骤 6 中的图像 1,3 Sony BDP-BX320 Optical Drive Replacement: 步骤 6 中的图像 2,3 Sony BDP-BX320 Optical Drive Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Phillips #1 Screwdriver
      $5.49
      • Use a Phillips #1 Screwdriver to remove the two 7 mm screws that secure the optical drive to the frame of the device.
      • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector located between the two "no fuss" ribbon cables that are attached to the board. This action puts the connector in the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers or your fingers to gently pull the cable out of its socket by the blue tab.
      • You may damage the cable by gripping it directly.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      • Pull the other two "no-fuss" ribbon cables straight out of their socket to disconnect them.
      询问修复机器人
      添加评论
    3. Sony BDP-BX320 Optical Drive Replacement: 步骤 7 中的图像 1,1
      • Carefully lift the optical drive out of the device housing.
      询问修复机器人
      添加评论
结论
By following these steps, you should have successfully replaced the optical drive in your Sony BDP-BX320, and resolved playback issues due to a faulty drive. To reassemble, follow these steps in reverse order. Carefully replace the outer casing if needed and screw it back into place. Ensure all screws are tightened, but avoid overtightening.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 5-2, Kershman Fall 2024 CSU Los Angeles, Team 5-2, Kershman Fall 2024 的会员
CSULA-KERSHMAN-F24S5G2
6 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 344
