跳转到主内容
加入维修社区 - 创建账户
Sonos One Control Panel & Microphone Replacement
你所需要的
  1. Sonos One Control Panel & Microphone Replacement, Protective Cover: 步骤 1 中的图像 1,3 Sonos One Control Panel & Microphone Replacement, Protective Cover: 步骤 1 中的图像 2,3 Sonos One Control Panel & Microphone Replacement, Protective Cover: 步骤 1 中的图像 3,3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
    询问修复机器人
    添加评论
  2. Sonos One Control Panel & Microphone Replacement: 步骤 2 中的图像 1,3 Sonos One Control Panel & Microphone Replacement: 步骤 2 中的图像 2,3 Sonos One Control Panel & Microphone Replacement: 步骤 2 中的图像 3,3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    添加评论
  3. Sonos One Control Panel & Microphone Replacement: 步骤 3 中的图像 1,2 Sonos One Control Panel & Microphone Replacement: 步骤 3 中的图像 2,2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    询问修复机器人
    添加评论
  4. Sonos One Control Panel & Microphone Replacement: 步骤 4 中的图像 1,3 Sonos One Control Panel & Microphone Replacement: 步骤 4 中的图像 2,3 Sonos One Control Panel & Microphone Replacement: 步骤 4 中的图像 3,3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    询问修复机器人
    添加评论
  5. Sonos One Control Panel & Microphone Replacement: 步骤 5 中的图像 1,2 Sonos One Control Panel & Microphone Replacement: 步骤 5 中的图像 2,2
    • Slide the protective cover upwards to remove.
    询问修复机器人
    添加评论
  6. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: 步骤 6 中的图像 1,3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: 步骤 6 中的图像 2,3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: 步骤 6 中的图像 3,3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    询问修复机器人
    添加评论
  7. Sonos One Control Panel & Microphone Replacement: 步骤 7 中的图像 1,2 Sonos One Control Panel & Microphone Replacement: 步骤 7 中的图像 2,2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    询问修复机器人
    添加评论
  8. Sonos One Control Panel & Microphone Replacement: 步骤 8 中的图像 1,3 Sonos One Control Panel & Microphone Replacement: 步骤 8 中的图像 2,3 Sonos One Control Panel & Microphone Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    询问修复机器人
    添加评论
  9. Sonos One Control Panel & Microphone Replacement: 步骤 9 中的图像 1,2 Sonos One Control Panel & Microphone Replacement: 步骤 9 中的图像 2,2
    • Pull the control panel away from the speaker to separate.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Marcus Glowa
于02/14/18注册
1,134 声望
创作了5篇指南
团队
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 的会员
USFT-NANCE-S18S2G1
3 名成员
创作了14篇指南
1指南评论
where can I buy a replacement control panel?
Chris Myers - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 99
总计 8,484
