跳转到主内容
加入维修社区 - 创建账户
Solio CLASSIC2 LED Light Replacement
你所需要的
    1. Solio CLASSIC2 LED Light Replacement, Disconnecting the Battery: 步骤 1 中的图像 1,1
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      询问修复机器人
      添加评论
    2. Solio CLASSIC2 LED Light Replacement: 步骤 2 中的图像 1,1
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      询问修复机器人
      添加评论
    3. Solio CLASSIC2 LED Light Replacement: 步骤 3 中的图像 1,3 Solio CLASSIC2 LED Light Replacement: 步骤 3 中的图像 2,3 Solio CLASSIC2 LED Light Replacement: 步骤 3 中的图像 3,3
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      询问修复机器人
      添加评论
    4. Solio CLASSIC2 LED Light Replacement: 步骤 4 中的图像 1,2 Solio CLASSIC2 LED Light Replacement: 步骤 4 中的图像 2,2
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      询问修复机器人
      添加评论
    5. Solio CLASSIC2 LED Light Replacement: 步骤 5 中的图像 1,2 Solio CLASSIC2 LED Light Replacement: 步骤 5 中的图像 2,2
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      询问修复机器人
      添加评论
    6. Solio CLASSIC2 LED Light Replacement: 步骤 6 中的图像 1,2 Solio CLASSIC2 LED Light Replacement: 步骤 6 中的图像 2,2
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      询问修复机器人
      添加评论
    1. Solio CLASSIC2 LED Light Replacement, Circuit Board: 步骤 7 中的图像 1,1
      • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Solio CLASSIC2 LED Light Replacement: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
      • Gently lift the circuit board out of the device using tweezers.
      询问修复机器人
      添加评论
    1. Solio CLASSIC2 LED Light Replacement, LED Light: 步骤 9 中的图像 1,1
      • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attemptingDesolder the LED lights.
      • Desolder the LED lights.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Eric Padilla
于10/21/13注册
201 声望
创作了2篇指南
团队
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G28
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 623
