跳转到主内容
Sol Republic Deck Volume Buttons Replacement
Rebekah Simmons
Rebekah Simmons4 其他贡献者
最后更新于 December 22, 2015
15 - 20 分钟
中等
The volume buttons on the speaker are two black buttons located on the front of the device. The volume up button, which increases the sound of the speaker, is on the right side shaped like a plus sign (+) and the volume down button, which decreases the sound of the speaker, is on the left side shaped like a minus sign (-).
你所需要的
工具
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  1. Sol Republic Deck Volume Buttons Replacement, Volume Buttons: 步骤 1 中的图像 1,2 Sol Republic Deck Volume Buttons Replacement, Volume Buttons: 步骤 1 中的图像 2,2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • To separate the front face plate from the bottom half of the speaker, insert a spudger into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck Volume Buttons Replacement: 步骤 2 中的图像 1,2 Sol Republic Deck Volume Buttons Replacement: 步骤 2 中的图像 2,2
    • Locate the black plastic volume buttons on each side of the back of the speaker face.
    • A piece of black tape on the side panel may also be covering the yellow connector tip that holds the volume button in place. Remove the black tape if necessary.
  3. Sol Republic Deck Volume Buttons Replacement: 步骤 3 中的图像 1,1
    • Using the plastic spudger, pry the button from the front plate of the speaker. The volume button is connected to the speaker by a plastic tab that has blue glue holding it down. The entire volume button can be removed from the front plate by carefully using the spudger to lift it up until it comes off.
结论
2等其他人完成本指南。
3指南评论
Thanks for the help
Rebecca Parrish - 回复
No problem! Glad you were able to fix your speaker :)
Shelby Ray -
So I dropped my speaker from 2 ft and the volume up doesn't work even after opening it up and trying to replace it. Is there any thing I may have missed?
nick ed - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 10
过去 30 天: 18
总计 1,274
